patiolatern
Did not find much info here or in my wider searches for info on this so I thought I would make a thread for it.
The motor seems to be running very smooth after going through a number of updates -Thanks Jerryjerry05- I still have the problem of leaking fuel from the quick connect fitting at the motor. The motor will not run continuously on its own and I need to continue to squeeze the bulb to keep fuel flowing.
The o ring on the motor male connection was very poor and I found an O ring that seemed to fit well.
The female connector O ring also looked very poor and basically broke apart as soon as I touched it. I scrapped this out and also replaced it with one I had and it also appeared to fit ok.
The seating seals on both the male and female look okay. I never touched them and there is no fuel leak when not connected.
At first the leak seemed to stop but upon starting the motor and priming the engine the leak was still there.
Knowing the O rings I used were temporary I contacted Franz Marine (thanks JerryJerry05) to discuss weather I should just replace this fitting with a more common or newer Johnson connection. I would then have to some how zip tie or secure this in some manner.
Franz indicated that the O rings are just over $1 or so each but he doesn't have any at the moment. I am going to see if our local Mercury dealer has them. Franz gave me the part #'s:
F17817
F17816
I hope the motor stalling is directly related to this but I will also check any other connections for tightness. I am using the original fuel tank but have replaced the hose and bulb.
Thanks for reading and any tips/advice is appreciated.
F17817
F17816
