haffiman37
Silver Medal Contributor
"All the 25" engines from
"All the 25" engines from late 80's had V6 gear cases, BUT V4 ratio. Even if a V6 case and ratio, the 10 minutes it takes to pull the bearing housing to verify C or not might be well spent!
With a V6 gear ratio, I would suggest to pick a prop that runs as close as possible to 5500 or he will loose out too much in the hole shot."
