Bob Komischke
Hi Folks! I just found this forum, and I'm hoping to get some help diagnosing a problem with my 140 MerCruiser sterndrive. It's a 1973, in a Larson All American. The boat was my dad's, who passed away a couple years ago. The boat had been garaged, unused, for quite a few years, and is like new, only 275 hours on the motor. I brought the boat in to a mechanic last year to go over the engine after all that sitting. It starts great, runs smooth, but here's what's started happening. After I'm cruising for a while, say 15-20 minutes, not wide open, maybe around 3200 RPM, the engine will start to sputter (almost like it's running out of gas), and eventually die. I can get it to start again, but it won't keep going. If I let it sit for a bit, it'll start, and run for a while, and then quit again. If I let it cool off completely, it'll start right up again, run good for a while, then the same behavior. It seems like something is happening once the engine runs long enough and something gets hot enough. I'm hoping this sounds familiar, and someone can suggest what needs to be fixed that I can do, and avoid pulling the boat out of the water and hauling it back to the mechanic. Any ideas? Thanks
