Search only provided this Link .
Just did the pump didn't see any obvious signs of failure (here's your sign ) . Reassemble thinking o-ring must have leaked . Nope .
So it appears the only way to check the water tube is pull the power head .
Unless there's a work around or another solution. . I am all ears .
Thanks tony
https://www.marineengine.com/boat-forum/threads/water-coming-out-of-lower-unit-in-odd-places.484970/
My issue is I have water coming out of the area by the lower mount covers . When it's not running it drains down then stops .Just did the pump didn't see any obvious signs of failure (here's your sign ) . Reassemble thinking o-ring must have leaked . Nope .
Thanks tony
