Trollineye
Hope Joe Reeves sees this, if not anyone else who can help would be appreciated. I rebuilt my 1986 140 looper and when I connected the main harness and conectors back together, I crossed the trim sending unit to the VRO pump connector (they are the same). Noticed the trim gauge wasn't working and discovered the problem with the connectors and fixed the trim gauge. Now the warning horn goes off when I ground the over heat thermoswitch but doesn't sound when I turn the ignition on like it used to. Is there a circuit board in the oil tank I may have destroyed? I can't find a schematic for the entire horn circuit. I also set the timing the way Joe suggested by removing the plugs, timer base against the stop (full throttle) and cranked her over. My air box cover and manual calls for 18 degrees BTC. It was at 4 degrees and I cranked it out to 14. Hard to believe it was that far off. Did I miss something or disturb something in the rebuild? Thanks all. Bob
Joe, BTW I fired her up last night and she sounds great. Has a total of 3 minutes running and will be in the water tomorrow to get through the breakin period.
