"I have a 1996 135 Mariner V6
"I have a 1996 135 Mariner V6 outboard and it overheats only when engine is working hard, ie, trying to get up on plane. Temp OK up to 2000 rpm, overheats between 2000-3500 rpm, then temp comes back to normal when above 3500 rpm. I have replaced both thermostats, poppit valve assembly, all hoses after the water pump, water pump kit, and pulled both heads and replaced head gaskets. Heads and cylinders very clean, no corrosion. Tell tale is normal. Same problem when running without thermostats. Any suggestions as to where to go from here? Thanks."
