"Hi, I still working on my 198
"Hi, I still working on my 1986 135hp mecury. I was able to take the boat out again to see if the hose at the bottom of the crankcase being off was the idle problem but it wasn't . I got alittle more faith in the motor though when we tried it this time . This is just the second trip overboard. The outboard runs forever in any throddle postion but the creepy crawl idle then she seems to lean out sneeze and cut off. every time it cuts off it starts up quick. I'm pull'n the carbs off today I might even just pull the top carb cause that's where the problem is, the top 2 cylinders. Engine don't run on the top 2 cylinders when idling . I pulled the spark plug wires off at a idle and with both wires off you can't even tell that the wires are off. But the second you crack the throdle with the wires on you can tell she picks up but cylinders right away. So it's just at a idle the engine won't hit these 2 cylinders. The engine has good power and compression on these cylinders 115-125 psi. The oil injection system has been pulled off. Bandit told me to check the carbs and to make sure the "Bleeder" lines are in place. Sooooooo to be honest I don't know where the bleeder lines go and excactly were they are. Are they at the back of the engine on each cylinder ? Small rubber lines that come off the cylinders and some look like they go to the carbs and some look like they may go to a switch. But the thing that conserns me is that the top carb has a small tee fitting on the top of it and someone has just hooked this fitting in a loop. Hose comes out one side of the fitting and connects to the other side of the fitting, is this right or not because this is the carb that i have the 2 dead cylinders on at a idle. Thanks for your time and help
Scotty"
Scotty"
