Old School
Hi Everyone. New to this form. I have a 1990 125 HP 2 cycle oil injected outboard that floods after it has been run for 10 minutes. I'll make a run to a fishing spot and fish for 20 minutes to an hour and try to start the motor and it is flooded (bulb is hard). I disconnect the fuel line and open the throttle up and it starts, creating a huge cloud of smoke. I hook the fuel line up and if it hasn't cleared the plugs yet it will load up and die. Replaced floats and needles in the carbs. Provided a short cure 3 uses. Back to the same thing. Rechecked carbs with no notable problems. Checked float levels again and they were still good. I have had it load up and quite while running slow. Any ideas or suggestions would be great. Thanks in advance for your help and advice.
