S
short_dog
Guest
"Hello All,
I have a 125AQ.
"Hello All,
I have a 125AQ. I have had a problem with the coil overheating. A few months ago I replaced the coil with an automotive ACCELL coil. Eeverything was fine until a couple of days ago it overheated again while at idle and tied up to the dock. It got hot again and I couldn't restate the engine. After it cooled down it restarted. I read in the Seloc manual that if the "primary resistor" had more than 1.4 ohms it had to be replaced. The problem is I can't find the primary resistor. Is there a special coil for a primary resitor. Thank You."
I have a 125AQ.
"Hello All,
