Hey gang. I hope you don't mind a long post too much. Today was my first time working on a marine engine/drive and I have all kinds of questions rolling in my head
I put on a set of muffs over the vertical holes below the anti ventilation plate. I'm hoping this is the right spot for the water p/u. After starting the engine, I was expecting to see water streaming out from somewhere, but did not.
I shut it down and after thinking about it decided that it may take some time to fill the cooling system.Started it again, but still did not see anything and shut it down before the temp gauge got to high.
I read in my manual that you will not see any water return if the thermostat has not opened, so started again and let the temp come higher.-no luck. I did notice that for a short time there was a fair bit of black water that started coming out by the prop shaft.
I wondered if the water supply was not working properly,so I submerged the drive in a barrel up to the anti ventilation plate-no luck.
I saw in my manual that it says to make sure the water is coming up through the pivot points.Not sure how to check this so I pulled both covers off and started it again to see if water was coming through-(nothing). I also pulled the 2 lines that go to the front of the exhaust manifold and the one that goes to the exhaust elbow.(no water)
I think that all of this would mean that the lower water pump is not working.I'm just wondering if anyone has anything to add as to what else I might check or do different before tearing into the stern drive.Also wondering where I should see the water return from and what about the water coming from the prop shaft?
Sorry for the length.
