120 V4 Evinrude Quits
A
Andy Turner
Guest
"Everytime out after about 15
"Everytime out after about 15 min it just dies, no spark. won't start again until evening or morning. Someone suggested replacing the CDI ?
Any Advice?"
"u need to ck the spark,when t
"u need to ck the spark,when this occurs..if in fact,u have no spark,then the pack would def be suspect...but,...an overheating stator can ,and does cause this prob too."
I put in a new CDI and fired i
I put in a new CDI and fired it up. It ran for about 2 min and then quit. Would not start again. I gave it some more primer and it still would not start. The next day it would not start and the plugs were very wet. I checked for spark and it looks good. Any Ideas ?
"ck--compression
pull a fuel
"ck--compression
pull a fuel sample--ck'ing for water,any water--this is critical,in your case.
then,u would need to do the ign/electrical tests,for stator,and timer base--u will need a factory service manual..or---u can download,excellent elect trblshting info,from cdi ignitions."
I could not get the engine to
I could not get the engine to fire so I put the old CDI back in and it fired up. The new CDI has a part number of 584041 and the old CDI has a part number of 584040. I searched in parts and its confusing as to what the 041 replaces. Do you think I need to re-order or ask for the 040 part or should the 041 be the correct part but maybee this ones faulty?
Ps it was nice to hear the engine run again.!
