OK I think I stumped the Yamaha mechanic so I need some help from the pros on here! I have a 2001 Yamaha 4stoke. Never had a problem till recently. My VHF turned red, started beeping, and displayed "Battery Voltage too High". Noticed the battery voltage at 14.8. Usually with a full battery and running it stayed around 14.2-14.5 volts. If I turned on a pump or lights or something it would hold around 14.5 but as soon as I turned off the load it would shoot back up to 14.8. Got home did the usual, checked and cleaned all connections, used a good digital meter, and checked the battery. At idle on the hose still held at 14.8. Went to the dealer and he advised the regulator was probably bad. Bought a new regulator ($150), put it on, same problem. Changed the battery, seemed to take longer to charge up but still same problem. Went back to the dealer and he said that he has no idea what's wrong but for $80 an hour he would "play with it" and see what he could figure out. I don't claim to be a professional mechanic but I've wrenched on motors my whole life. I believe the motor has a stator, regulator charging system so I can't figure out how it is overcharging. The old 2 stokes sometimes had a problem with diodes or bad connections that caused over charging but I've checked all that. The regulator is a hefty 6 wire heat-sinked unit. Hate to think that that the new one was bad out of the box. So, is 14.8 "that" bad? Seems high but the only symptom the boat has is the radio beeping "High Voltage". Would love to get a little input. Thanks for the help!!!!!! AL
