I wouldn't discount the 1985 or newer motors simply on the premise of VRO. You may find that most of the early motors have had the VRO upgraded to a newer model, converted to premix, or replaced with a fuel only pump. All of the cross charged V4's have the non VRO fuel pump boss on the engine block, so switching them is no big deal.
VRO is a proven system. It was standard equipment on OMC engines for 20 years. The vast majority of these engines are still running, and the VRO is still pumping away just like when the motor was new. If you search the archives, you'll be hard pressed to find someone who lost a powerhead to a failed VRO pump. You will however find instances of people that have blown stuff up by forgetting to pre-mix the fuel. It's your choice whether to trust it or not, but do some research instead of relying on the talk at the dock.
