115hp evinrude
firefox
motor is mid to early 80's
motor is mid to early 80's has run great last few days now when i go to throttle it the motor feels like it's free spinning when i back it off it's fine any suggestions please help
"Sounds like a spun hub on the
"Sounds like a spun hub on the prop. Mark the center of the splined portion of the hub, put a corresponding mark on the other side of the rubber hub on the prop itself. Run the boat until your problem occurs. If the two marks no longer align, time to get the prop re-hubbed."
What 60hp motor?? some yes som
What 60hp motor?? some yes some no.You also need to make sure that the pitch is correct.Not just any prop will do.
Not even close ---Do not bothe
Not even close ---Do not bother to try and fit a prop from a 67 60hp onto a mid 80's 115hp
