TomsSearay
So, after reading everything about the no start, starter spin issues, I started to look at all the electrical connections believing that I may have a bad connection. All the usual stuff; e.g. battery, starter and solenoid connections looked good. Then, I noticed the bullet connections between the voltage regulator and solenoid and stator looked burned. At first, I thought that it was the die-electric grease, but father inspection revealed that the connections were burned and the insulated connectors were melted together.???? So, Any thoughts as to what may be going on. The motor would be hard to start; eg. starter would spin without engaging, but once started would run fine until the next start. then the no start bendix spin would begin again. I would continue to bump the starter until it would engage again. What is going on?? TIA!
