OK,
So I have a older 115hp 2cycle i6. I believe it is 1984 model...
So for some backround, heres what i have done to this point.
When i got the boat and motor, i replaced fuel tank and line. motor wouldnt stay running at this point. After doing some testing i found that the gasket on back side of the fuelpump was bad. Changed that and motor would run and idle. at this point i did a thorough inspection and changed my throttle cables, all 6spark plugs, rebuilt all 3carbs.
With the new parts on the motor, I am able to get it started and idle out of water with muffs on, It runs beautiful and idles nice and low..
now to my problem, when i get in the water, again, it starts easy and idles well. However, once i put the motor in gear and try to get up to speed it bogs down. it will go strong for aboout 10 - 15 seconds then bogs out like it is going to die. I have tried adjusting the idle screw in and out and havent had any change.
if i am in water and just increase the throttle out of gear it doesent bog, only when iam in gear.
Any idea what i should look into?
