my outboard runs well for a few minutes then the fuel rail pressure drops off and the engine stalls , the lift pump works fine and the fuel rail pump runs to 42 lbs no load , a bit before it stalls you can see air and fuel going back to the main tank this is viewed thru a clear hose, it eventually lowers the fuel so the high pressure pump cant keep the fuel rail supplied and the lift pump won't kick in to refill the fuel module . how can air pressure get into the module to push the fuel backwards in the supply line????
