115 Yamaha
Is the fuel pump running for several seconds when the key is turned to the on position?
And when you say that it starts up using starting fluid does it start and continue to run or does it start and then die?
Sounds fuel supply related.
Do you know what the vapor separator tank is? It has the electric fuel pump inside. Hold your hand on the VST and when the key is turned to the on position you should be able to feel the fuel pump run. Or hear it.
If the fuel pump is inop the motor will not start.
