I've just completed rebuilding my 115 inline 6 and when I attached a water feed and sent water through the hose I was getting water through the pee hole. After starting and running, shuting down and restarting a few times, I went to check the side cover for temperature and it was hot, so I checked the pee hole and there was not any water coming through. Shut it down and let it cool, started it up about an hour later and still no water. The motor popped a connecting rod cap, which is why I rebuilt it. Cleaned and checked all the block covers before reassembly, and replaced all power head gaskets. I did not check the lower end or water pump before reassembling the power head. Could some of the blown chunks worked down to the water pump impeller through the exhaust?
I don't believe I have any debri in the power head, but I'm not sure how the exhaust funnels through the lower end, which is why I'm asking if some debri got into the impeller.
Thanks for any help!
