Hi all,
I have twin 115 opitimax 2011 models, 200hrs, smart craft gauges and have owned from new.
Right hand engine is throwing low water pressure alarm when key turned on. I have swapped pressure senders and fault stays with the engine. Sender works fine on LH engine.
Water pressure is fine when I ran it with sender removed.
Wiring from sender to ecm tests fine.
Would anyone have any ideas or experienced this problem before.
Thanks in advance if you can help me get back on the water
