115 merc oilfuel leak
flytyer
"Hey all
When the engine is r
"Hey all
When the engine is raised to the travel position it will leak out about a 1/16 of a cup of mixed fuel from the cowling---- any ideas??
cheers
"Hi there!
No sweat, this i
"Hi there!
No sweat, this is normal. Carb's have breather holes and juice will weep thru there when motor is tilted. Don't plug those holes in the carbs... Can't answer why, but don't.
Regards from a warm and wintery Johannesburg in South Africa!
Benjamin."
Your best bet is to disconnect
Your best bet is to disconnect the fuel and let the carburetors run dry.---- no more leakage and fire hazard.
"Hi there!
Would not recomm
"Hi there!
Would not recommend doing this, the carbs would run dry and you'd have no lube in the motor as it winds down from idle.
You'd have to kill the motor at the precise point before fuel is done for...
Rather use drain screws on carbs with a cloth if this "leak" is such an issue.
Regards!
Benjamin."
"fuel leaking from the carbs i
"fuel leaking from the carbs is normal when tilted at an extream angle. Keeps everything lubed
. Happens to me every time I look at my watch, my beer spills on my foot."
"it seems strange that this wo
"it seems strange that this would be normal as it would be a fire hazard and Muercury could be held liable due to this. There must be a proper answer to this, but i do like the one about the beer"
"This topic is covered a lot i
"This topic is covered a lot in the forums,have a look in search and it may put your mind at ease.JB is right"
"Running the carburetors dry i
"Running the carburetors dry is the best thing to do------No the oil that is in the engine and on pistons and bearings does not " instantly disappear " when one carburetor goes empty first , that is just nonsense."
"Hi there!
Just occurred to
"Hi there!
Just occurred to me that the float level might be too high?
I've seen many a motor, various makes and models, that has this symptom of leaking fuel when tilted to max height. Then again, I've also seen the same makes and models that does not do this. Both my motors does this, one being a Sea Pro 55 pre-mix tiller (1998 vintage) and other being an Offshore 115 AutoLube (1997 vintage). Maybe these owners are running carbs dry?
Makes sense that manufacturers would not design them with this problem due to liability issues.
Would a breather pipe connected to the overflow hole solve the problem?
Hope you find a solution to this messy and potentially dangerous situation. Let me know what the best outcome was.
Thanks all!
Over & Out!
Benjamin."
"Ben,
Thanks for your thought
"Ben,
Thanks for your thoughts. I will be looking at the float level as if it is to high and there is a breather hole!!!!!! may make sense
cheers"
"JB maybe you should either we
"JB maybe you should either wear your watch on the other wrist or stop worrying about the time as you are wasting prescious beer my friend. oh and on the subject or the fuel from the carbwhen tilted, mine does it, its ok stops having stale fuel sit in the carb which can varnish up if left to long."
