"OK GUYS I still need some hel
"OK GUYS I still need some help!!! I have reviewed the service manual. The trim and tilt performs every operation it should with the exception of the tilt. The unit will hold for the shallow drive under power, reverse lock holds and the unit will trim in and out. The unit will hold position for days without any drift down. The trim out seems a little weak but will work if you take the throttle back to idle. The tilt will work only if you assist it. What is the most probable cause. I am thinking the hydro pump is weak. Your thoughts?"
