greghennings
Hello, i've been having a major headache trying to get my 78 115 johnson to run. i bought it last fall, and it did start and run. Over the winter i fixed everything i could within the limits of my abilities, one being rebuild the carbs. Really isnt much rebuild as much as cleaning out and replacing a gasket and o-rings. But now i can't get the thing to start, on gas, it will start on starting fluid and i can get it to run but when it runs i can tell gas is coming out of the bottom carb but not the top carb. I rebuilt the fuel pump also, and if i disconnect the top carb and crank the motor, the fuel pump is pumping gas.
compression, #1 95 2,3,4 105.
i have spark on all four and have brand new plug firing really good. if i had an ignition problem, and/or compression problem, at some point when cranking over this motor i should get some kind of pop or bang and i don't get anything.
i took the motor to a local marine mechanic and was told because the compression was low i'd need a new powerhead to the tune of over $4k installed. I just think he didn't want to waste his time with me.
Any ideas would be great, getting a little depressed and upset with myself about this, we're supposed to be going to MN in a couple weeks fishing, because of the long winter and busy schedule i couldn't get the motor outside to start it up until last week.
