115 JOHNSON 2 STROKE TROUBLE
spaner911
"ok i BOUGHT A USED BOAT AND I
"ok i BOUGHT A USED BOAT AND IT HAS A 2005 JOHNSON 115 2 STROKE ON IT. NOW THE BOAT SAT FOR 9 MONTHS PRIOR TO ME BUYING IT. AT FIRST THE MOTOR WORKED OK. THE 2ND OR 3RD TIME I TOOK IT OUT IT WAS HAVING PROBLEMS STAYING RUNNING AFTER IT WAS STARTED AND IF YOU THROTTLED UP A LITTLE IT WOULD DIE OUT. IT WOULD GO SOMETIMES IF YOU SLAMMED THE THROTTLE FORWARD. NO I HAVE EMPTIED THE FUEL TANK REPLACED ALL FUEL LINES, WATER SEPERATOR AND REBUILT THE CARBS. NOW THE MOTOR WILL ONLY START IF YOU PUSH IN THE NEEDLE ON THE FUEL PRESSURE REGULATOR I THINK THATS WHAT IT IS CALLED, IT LOOKS LIKE A VALVE STEM ON THE TIRE. ANY IDEAS ON WHAT COULD BE WRONG"
