115 Hp 2 Stroke- Trouble with keeper pin, trying to replace water pump
captb
Anyone have a trick for removing the pin from the shaft when trying to replace the waterpump assembly?
I removed the impeller and now can't get the pin out of its slot on the shaft. Can't go any further with the repair 'til i can get that pin out.
Help!
Thanks, B
I should have said I've left it "soaking" with some PB Blaster on it. My experience with other pumps, is the key came out pretty easy, so this one's got me stumped. I could slide the new impeller over the old key, but I'd really like to replace the bottom plate and gasket.
Thanks, B
finally banged it out. man, i thought i was going to beat a hole through the drive shaft getting it out.
thanks for the info.
B
Woodruff key.
Corrosion causes it to stick.
Bearings are pressed in and driven out. No different than a woodruff key.
