Stevekfisher
Just filled top half of the tank with non methanol gas. Launched my pontoon ran up to 6 grand ran perfectly then started bogging it never missed or cut out just like you threw the anchor out. Got it to my dock and parked it. 08 suntracker. The I Realized I had the main power switched “off”. Earlier I Had noticed just touching the trim switch affected itrunning for a second seemed like an electrical surge changed the running of it. One guy says the main power was the problem. One guy says no way won’t affect the running. And tells me drain the water fuel separator should be a petcock on the bottom. I can’t seem to figure that one out it’s in the water on a lift so not easy to do but can’t find a drain valve. Any help????? Also what else to try.
