skydiverbill
"C115TLRY dom 9/1999
ok ch
ok check for spark, none, primary side of the coil has less than 5 volts, checked the thermo swiches, ok, lanyard and ignition kill circuit on the white wire is ok grounded on off and open on crank and run, checked ohms on all 4 coils (pulser and charge) and check for grounding of coils, all ok. check the coils cranking, all produce the right voltage.
what i need to know the 9 way connector has 7 wires coming from it
I know 4 of them. what are the other 3?
black -ground
white- engine kill
grey /black stripe thermo swiches
yellow- 12 volt key on-crank power
green- tach?
pink ?
brown ?
how often do the cdi units go bad, ran fine last time used.
thanks"
ok ch
black -ground
white- engine kill
green- tach?
pink ?
brown ?
thanks"
