My 115 - 4 stroke was runing fine last Aug. it has been on the Barge setting in a boat house since that time, i changed my add on water filter, and put in fresh gas w/ heavy dose of Marine Sta-bal, when i crank it up it runs fine, i can take it out of gear and rev it up hold the tech at 4 gran, but take it out on the water and once i get to about 2000 rpm it bogs down, i called my Mechanic (who is a long way from me) he said first thing is to check the water pressure, i have none, but the little boy is peeing out the back, he thinks my water intake may be fouled from setting in the water all winter, my Question to You'll is do you know how to clean the water intake other than using a brush on the out side and clean it real good, i am think of taking the rig out of the water and the before i hook up a water hose to the clean out connection, pouring a cup or so of Bleach down the hose then connect it to the motor and run the bleach trough the system, once i do that i will put a treatment of sea foam in my tank and run the motor then let it set for a while incase my injectors or dirty, do any of you have any think that you can point me at to try and keep from having to drag this rig 50 miles tohave it looked at, Thanks for what ever you can do to help this Old Man
