Hi there
I am having a little trouble getting my outboard to start first time, once running for a couple of minutes it starts absolutely fine.
Although initially after turning over for a few minutes it eventually coughs into starting with what you could say is an unusual amount of white smoke and then runs fine without the excessive smoke.
The plugs are relatively new & I recently checked the plugs & they seem fine.
Could you possibly recommend me other trouble shooting methods to try and rectify this problem.
Would a compression test be any use, anything to do with the fuel pump, what about carbs flooding?
Starter motor works fine solenoid works fine & generally the engine is in very good condition considering its age due to very little use.
Would greatly appreciate your help.
Cheers,
Craig
Cheers,
Craig
