"The full spark advance timing
"The full spark advance timing is adjusted via the adjustment screw that has the black rubber button attached to its head, located at the top front port (left) side of the powerhead. You'll notice the timer base under the flywheel advance to it as the throttle is anvanced.
The full spark advance timing of your engine is 28°
It can be checked and adjusted if needed as follows.
(Timing At Cranking Speed 4°)
(J. Reeves)
The full spark advance can be adjusted without have the engine running at near full throttle as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig a spark tester and have the gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for.
Your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°.
If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
When time permits, visit my store at:
