catfishin_welder
I've checked for spark. Real Good spark on all 3 holes. Replaced plugs, 200-199-200 psi top to bottom. Cleaned VST, checked high pressure fuel pump, it's good, cleaned screen under it, cleaned float, needle n seat, new vst gasket. Replaced high pressure and low pressure fuel filters, cleaned throttle body, verified white wire fuse good, replaced main relays. Verified neutral switch operating. Replaced cam sensor. Tried swapping ecm with with known good ecm. All I can get it to do with either ecm is a small pop when cranking over but if I pull plugs and shoot juice in and put plugs back in she fires right up at instant from key turn. Im thinking fuel pressure regulator, or fuel injector issues? Anyone got any other ideas?
