I've got a pair of these with about 700 hours; I'm trying to diagnose a rough idle on one of them.
I say rough idle but it's more like it idles perfect (out of gear) for 5-10 seconds at around 540 RPM then it stumbles momentarily with the RPM dropping to under 500 then it recovers and is fine for some period of time. At anything above idle there is no problem noted, including wide open.
Compression with my gauge is 115 a cylinder +/- 2 PSI. What the book says to do is check plugs, check air pressure, check injector resistance, check coil resistance...
Air pressure seems the same on both engines - like 80 PSI. The gauge vibrates constantly with the engine running but is centered there. When I shut the engine down it starts about at 80 then you see the pressure draining off. Both engines seem to do this, assume it's normal but worth mentioning.
Plugs were fouled but I did just run a cap of extra oil through the engine (put into filter to winterize) so I don't know what that really means. For some reason though #2 and #4 (port side upper ones) were noticeably less fouled, almost "normal" but on the dirty side for only have 50 hours on them. Maybe that means something. Changing plugs was no help at all.
No issue found with resistance on all 12 injectors, nothing even more than .1 Ohm from the spec - which has much more tolerance than that by the book.
I bought a used coil harness on ebay so I can plug in and check coils, but I don't have much faith in that showing anything as it seems unlikely a coil would be bad without it being more noticeable.
Two issues I'm aware of. The fuel test valve on this engine leaks, doesn't spray but just sorta drips and runs down the fuel rail. When testing though I stopped the leak by putting a better-than-stock cover on the valve (until my new valve shows up)..
The air compressor on this engine always has what seems to be a film of oil on the back side of it - seems to have a weep of some sort from under the pulley. It's been this way for awhile. I have O-rings coming so may fix this but given pressure is good,, it seems like a cosmetic issue; can anyone comment on whether this probably is oil leaking out of the seals under the pulley? Is there that much oil in the compressor to have such a weep?
Anyway - Seems like if I've got a spark problem it's impacting at least 4/6 cylinders, if not all of them. Is there anything that could do this? Else any idea where I should be going next if the coils check out?
I have the luxury of swapping pats from one engine to the other if there are some expensive frequent offenders that would be nice to remove as variables.
Thanks in advance.
Jon
Thanks in advance.
Jon
