Nice to see you back Joe. I absolutely know it has been tough.
Suzuki Johnny. First place I would look is at the harness to the engine basically up at the control box.
This engine MUST have +12 volts present at the EMM to operate. It sounds like there might be a loose +12v wire in the control box causing engine to shut down, and also intermittently shorting to the starter solenoid pick circuit. Look at the terminals on the back of the ignition switch and make sure they are not touching each other.
I saw one switch where the terminal was swaged onto the back of the switch, and the swage was loose, causing the terminal to rotate, and make contact with the terminal next to it.
1. Turn key to ON. You should hear the main relay click, and you should hear the HP fuel pump run for about ten seconds.
2. Find any gray wire that is easily probable with a voltmeter. Usual place is at the ignition coils, or at the HP fuel pump connector.
Measure voltage on that gray wire...should be +12v with key on.
3. Find White wire going from engine to harness, and eventually up to the control box. That should have +12v on it also.
Be aware that the wires change color due to the J/E harness adapted to the Suzuki motor. White on Suz is +12v. Red is +12v on J/E.
When switch is ON, gray wire feeds power back to the engine.
You will do very well to pick up a factory service manual, as this is a different animal.
You will not have a cam position sensor problem. That throws a code, and will cause a check engine light on the tach.
I think all the problems are in the control box, or ignition switch.
