04 Johnson 175HP How do I know if oil pump failed?
During my last great adventure on the high sea’s 2[SUP]nd[/SUP] day (first day no light) the no oil light came on so I turned off engine.
I have disconnected the oil line last engine running 3[SUP]rd[/SUP] week in Nov. added like 3 gallons of oil to reserve and I always press the bulb to build preasure usally it’s already so hard you can’t squeeze it.
Still the light so I disconnect at the tube just before it enters the engine purged there didn’t observe any air bubble reconnected still the light.
?1.should I have purged at the oil pump?
?2.if my oil pump went south wouldn’t the engine enter limp home mode and not allow me to rev past a certain amount of RPMs?
While I was at the dock preparing to leave I started talking to the man next to me he was having difficulty retrieving over some washed up sand and I asked if he needed a hand.
Anyway man had a set of late 90s 2 stroke yammies they still sounded good asked him about the reduced amount of blue smoke I;m accustomed to seeing he said it sounded good and just run it even w/ the light on. Come to think of it when the engine is warmed up the smoke is reduced I don’t like red lights on my engine error code.
So how
?3.How do I know if oil pump failed?
?4. doe’s the oilpump also pumps the fuel?
50 minutes after last cruise engine didn’t want to start at the rinse off lake. All that three weeks ago now I want to restart the engine.attach image at fresh water rinse off lake
I got good fuel the engine turns over I was thinking about removing a spark plug and look for spark during turning engine over maybe at night in the dark mite be a good plan because the ignition is 12’ away from engine or could I extend the spark plug wire w/ regular wire to watch for spark?
Thanks TB
So how
Thanks TB
