basserman1
"I had to replace the high pre
"I had to replace the high pressure pump about a month ago. The motor ran fine until the old pump died. The only thing I touched on the motor was the high pressure pump. Now, the motor will run for only 10 seconds. I have replaced the fuel filter, fuel bulb, and one of the low pressure pumps that leaked gas when I loosened the mounting bolts.
Now, all three pumps including the NEW low pressure pump leaks gas when I loosen the mounting bolts.
I cant get this thing to run. What else can I do?
Thanks!!"
Thanks!!"
