"Last fall while changing the
"Last fall while changing the LU oil, after installing the upper plug I pushed the last stroke of the pump into the the LU. Shortly there after I noticed oil dripping from the inside of the prop. There was no evidense of water intrusion in the drained oil. Do I have a bad prop shaft seal? If so, is that the only seal I should change? how hard is it to change?"
