ok got me a little tracker pro team 165 with a 2002 mercury-tracker 50 and last summer it had a major wiring meltdown around the voltage regulator, talked to local boat mechanic he said
400 to fix included new regulator and all the burnt wires redone. did all that and shes runnin good again and charging right etc. BUT after he pointed out the fact that since i had my deep cycle
hooked to the engine and trolling motor and everything else thats probably what caused it to blow because i was pulling way to many amps off the battery for the little 50
to put back in and it just tried and finally blew. so now i got 2 batterys a regular 12 volt for the engine and all my guages, radio, etc, and the 12v deep cycle is ONLY hooked to
my trolling motor and it has enuff power to pull my little tracker all around all day its an aluminum boat and the biggest baddest deep cycle autozone had and its a 45 lb
foot op but i dont troll all day anyway i usually run out my spots and maybe troll 2 hrs max all day so that batt still got tons power left. so just charge it at home with a plug
in charger and let the 50 charge the other isolated batt. ok sounds all good so far right? well after charging the regular batt, SOMETHING is drawing power off it with the key
OFF. so now im really confused because nothing should be drawing off that with the key off what my worry is that somewhere theres a short or something and the mechanic said
if there is ghost short that could cause another meltdown which im DESPERATE to not have happen again. so thats where im at and im needing advice, so if
anyone has any ideas on how i can figure out whats drawing power or what i should do please advise
