"Has anybody experienced this
"Has anybody experienced this problem with the impeller pump and housing, and how did you fix it? When the motor sits for a while without use the impeller and housing self destruct upon start. Seems like the impeller is fusing with the stainless cup which spins in the housing eventually ruining the housing and shredding the impeller. Prior to long storage I drop the lower unit and lube the impeller just to be safe, but now this problem seems to be getting worse. I'll be carrying an extra set with me just in case. Never had a problem with any other motors like this. Thanks for the help."
