"Clint, here's the exact w
"Clint, here's the exact wording from the service manual...
The rev limiter is activated through the PURPLE wire when the key switch is rotated to the “on” position.
The rev limiter uses a trigger signal (BROWN WIRE)to determine engine speed or rpm. If the engine speed exceeds the specified rpm, the rev limiter will ground out the CDM capacitor charge.
The capacitor voltage flows through the BLACK/YELLOW wires into the rev limiter and to engine ground through the BLACK wire.
(It hooks back into nothing else - simply receives "feeds" which go to ground if necessary.) If you never plan on replacing it, you could remove the wires right back to the switch box so they aren't sitting around under the hood..."
