"not discussed on this board,
"not discussed on this board, but have on the evinrude outboard. I have been reading some of you posts and you guys are just as helpful as the other guys.
Here's the problem. this is a 350 with carb. It sat for a couple years before this year. My girlfriend bought it, took it to the local shop, and they did the following. drained the fuel, replaced separator filter, oil change, and it did run fine for a couple weekends. last weekend, the boat would start then die at an idle. If I gave it throttle and pumped the accelerator piston a little bit, it would stay running. If I got the rpms up to 1200 to 1500, it would run, but when I idled down, it would die.
Anyone have any ideas. I thought fuel sep. or filter at the carb. Maybe fuel pump? One guy said that it sounded like the idle jet stopped. I'm pretty sure it's a fuel problem, and since it sat, maybe something out of the tank.
I won't be at the computer the rest of the evening, but would appreciate any ideas from you gurus. I am an aircraft inspector and technician, so I understand mechanical things, but I'm not familiar with these engines.
thanks for your help
Dan Catherman"
Dan Catherman"
