[email protected]
Motor:
Year: 2000
Make: Mercury
Type: EFI
HP: 200
Ok So i left the motor without the top cowling through a day of heavy rain. Not exactly sure that has anything to do with the problem i'm having but it started right after. Every time I turn on the battery switch the 20 amp fuse that is to the lower voltage regulator blows. I tested both regulators with a multimeter and they both have the same output. The motor was starting at first crank even when cold before this happened. Now without the fuse, the flywheel turns but the motor wont start. Checked for any visible fried wires and couldnt find any. Any help from you experts out there will be much appreciated.
thank you.
Year: 2000
Make: Mercury
Type: EFI
HP: 200
thank you.
