"Engine stalls and then when I
"Engine stalls and then when I re-prime the fuel
line bulb, it starts again only to stall after
running for a while. Carb was rebuilt last year. I took out the thermostat and the impeller was replaced last year so it's not the auto shut off. The fuel line hose from the gas tank is new and the vent on the cap is free. Fuel filter was also replaced. Fuel filter is clear so I
see it fill with gas and then as the engine runs
I see it being pumped into the carb by the fuel pump. There are no cracks in the fuel line that I can see? Anyone have any ideas what I can check next to correct this problem?
Thank you"
Thank you"
