Not to hijack this thread, I'm new here.
A hijack is a hijack.... but as long as we're here!
Will the AQ200 (305-V8) y pipe work on a AQ130 transom shield? (my AQ200 shield is rotted)
If this is an AQ200 B.... yes.
The AQ200B and AQ225B Y-pipes were single exhaust relief and were for the 3" O.D. exhaust outlets.
Does the AQ200 need the two small rubber hoses?
Those are the "rubber hoooks".
Again.... if this is an AQ200 B, it will be a single exhaust relief system.
The AQ130 only has one and is blocked by the single pipe exhaust anyway.
Any advice is greatly appreciated.
The AQ130 transom shield will be a 250, I believe.
The 250/270 uses the small collar steering fork shaft diameter.
You'll do better with a 280/275 4 cylinder single relief transom shield with the larger fork shaft diameter... IMO.
