hagadonecp
I have a 1986 75hp Mercury outboard (4cly). Just to Start, I'm not really familiar with boat motors. I can do the basics, but my brother in-law usually helps with indepth things. I had some starting issues a few weeks ago and we replaced the Stator (cracked), Flywheel (center was broke), and the Trigger (just because we were in that far). The boat started right up. It ran good with the ear muffs on and you could give it full throttle and it will go. I've taken it out 2 times since the fixes and when we first start it, it won't go full throttle. It will only go around 7mph and when you give it full throttle it seems to skip & buck a little but it won't rev up and go. It bogs down some, but doesn't usually stall. It will do this for a while. Usually we give up and fish for a couple hours & try it again. It will do it again, but after working on it 10 more minutes it all of sudden will kick in and go. It will run fine for the rest of the day. No idea of the issue. My brother-in-law thinks it's the timing, since we replaced those 3 parts, but he's not comfortable doing that. He's not really a fan of the outboards. Before i take it somewhere, i was wondering if it was the timing or if it might be flooding, air in the gas line (vapor lock), or something small. The Carbs were redone at the end of last year also. Runs great in Neutral & once it finally kicks in. Any thoughts?
Thanks,
Curtis
Thanks,
Curtis
