wiring diagram 1977 175 hp
scanner
scanner12
Hi,
I was given this wiring diagram attached, as the wiring diagram for a 1977 175hp V6 Johnson.
Could anyone verify that it is the correct wiring diagram for that model, also the fuse should it be a 30amp or 50amp.
Thanks in advance
Scanner
scanner12
scanner12
Re: wiring diagram
That's the wiring diagram for the PT&T but not for the engine. The fuse for the PT&T box was usually a 30 Amp #0511386. The engine fuse was a 20 Amp.
Re: wiring diagram
Thanks ezeke,
Yeah I forgot to add the PT&T.. it should have read
Hi,
I was given this Power Tilt & Trim wiring diagram attached, as the PT&T wiring diagram for a 1977 175hp V6 Johnson.
It is good to know that it is the correct one for that model.
Thanks again
Scanner
