Where's My Warning Horn Located
C74vette
I Have A 1989 Stratos With A Johnson 150GT. The Warning Horn Dont Work When You Turn The Key And I Can't Find It To Check It. Can Someone Help Me Out This Is My First Boat And I'm A Little Green At This?
Usually in the control box.-------Not all older controls " beep " when you turn the key on .-----------------Turn key on and ground tan wires coming from cylinder head to test horn.
Where Is The Control Box Then? My Key Switch And Shifter Are Mounted Into The Boat Not A Box. So Still Confused I Tried To Find The Wires You Need To Ground Out Using My Service Manual But It Wasn't Specific Enough It Said Pigtail Wire And My Motor Got 3 Coming Off By The Sencor On The Motor
You should have a warning horn under the console, most builders have them tied up to the wiring bundle. just have to look around for it.
