Where to find serial number on a 150hp force outboard
bvlp1019
I have what i think is a 1992 150hp Force outboard, the serial # is missing from the engines transom mount bracket, is there another place that i might find it on the engine??
There is a foundry stamp under the power packs and coils on the block.
Also under the bottom of the carbs on the intake manifold, there should be a foundry stamp.
The stamp is a circle with numbers around it.
The numbers in the center give the year the part was made.
It will get you close??
If??? it's still original on the boat??? Send the hull # to Bayliner.
You can also post some pics of the transom clamps, trim motor and the lower unit and the cowl.
It takes 3 or 5 posts to add pics.
Shutterfly or any photo sharing site will help add pics.
