dhearn0513
1995 Johnson 115 v4..I have been struggling with this problem for a while. The boat will run fine then it is start to act like it runs out of fuel @ wot. The motor will usually start right back up but then it will die when you try to go forward. It will spit and sputter and shut off. I can take the filter off under the cover and empty it. prime the engine and it will run @ wot for about 10 sec and then do the same thing. No milky stuff comes out of the filter like it had water in it. I have changed almost everthing.
All fuel lines from tank to engine.
New fuel filler hose.
New fuel line under the cover.
Checked Anti Siphon for tank. (No Anti Siphon).
Compression is fine 110, 110, 108, 108. This was not hot ready just warm engine.
This is the second engine doing the same thing on this boat. I had a 1985 Evinrude 120 that was doing the same thing..
I am now thinking about maybe having the tank cleaned by a professional. Thinking maybe something is blocking the pickup in the tank. I can keep the boat running as long as someone sits in the back and pumps the ball when the motor gets ready to shut off, you can tell when its getting ready to shut off because the engine starts to shake and stumble. This is a low rpm.....Also should mention the carbs have been cleaned... Help Please. about ready to sell...LOL
