wynjim55
After having the boat out for it's first run and having it fail a number of times I figured it was time to delve a little further. The engine seemed to run fine at idle but wouldn't rev out passed mid range. It opened up and ran perfectly for less than a minute before dying again. Eventually when we had limped back into the marina it refused to start.
Since then I've cleaned and put a kit through the carbs and fuel pump, replaced all the fuel lines and clamps, and had the carbs synchronised by the local Yamaha dealer. On picking it up I was surprised by how cheap it was but somewhat deflated when he said he thought the crankshaft seals seem to be worn and that the engine seems to have trouble sealing to draw the fuel through the system. Once he got it started it ran and would even start after being switched off, but he seemed to be saying it might last ages or not go anywhere.
He said they wouldn't be interested in doing the work to replace the seals and after previously fighting with a lot of the stainless bolts in alloy housings I can see where he is coming from. I still intend to take the boat out for a run to see how it goes.
Should I be taking the risk on this engine leaving me stranded? I only intend staying in the relatively sheltered waters between mainland Australia and Fraser Island. Naturally a new outboard would be an ideal situation but I can't see that happening any time soon.
