Re: what prop pitch?
Maybe the prop is not your problem ! Maybe it's the motor. Want to find out ?
Very simple we find out if the motor is operating as it should then we all together can come up with a solution for a good outcome in your case.
So lets begin : Beg, borrow, steal a compression gauge, one that screws into the sparkplug hole.
Put the throttle fully down remove all the plugs, and keep them in order, so you know what plug came out of what hole understand, mark them, tag them, do what you have to,so you know what plug came out of what hole.
Screw in the gauge and crank the motor till the gauge stops, say 5-6 times. Maybe less.
Write down the number, and what plug hole make a diagram if you have to, do each hole.
Read the plugs, heres how.
Spark Plugs
Post back we can go from there.
Or you can blow me off buy 50 props and still not have the boat do what you want it to do. Then i will know i wasted my time trying to help you.
It's your choice.
